INVERTER DELAY LTSPICE
ANALA M REDDY
Joined Aug 14, 2017
22
I have simulated the inverter using LTSPICE...I m using this tool for the first time...I want to
1. measure the inverter delay
2. plot delay vs supply voltage
May i know the procedure to perform these two steps..
WBahn
Joined Mar 31, 2012
33,122
A better circuit is to have your ideal source drive one of your inverters, have that inverter drive the inverter you are testing, and have the test inverter drive some number of other inverters (whatever fanout you want to spec your delay measurments at).
By driving your test inverter directly with an ideal supply, you have potentially unrealistic rise-fall times and drive currents driving your device, which can give misleading results. By having it drive other identical inverters, you know you have a realistic load instead of a load that you may not have any concrete basis for.
