inversion of signal into active baxandall tone control
dumbretard123
Joined Jun 18, 2024
22
Sim of a slightly different Baxandall circuit:
It has only one 47nF (C3) instead of two.
Connecting CB1 and CB2 as you show, distorts the response at the mid settings in my simulation (bottom curves).
Yep thanks, I just built your circuit as well, and it works. But the reason mine didn't work was because I still had some weird paramaters scrambled all over the file. Been too long since I last used LTspice.
Now it works.
dumbretard123
Joined Jun 18, 2024
22
Sorry. got a bit confused there. this is actually the circuit that TI suggests - using virtual ground. I adjusted it for a symmetric supply. It seems to have a flat response at 50% wiper.
For some reason the step parameter returns this ghibberish.
ericgibbs
Joined Jan 29, 2010
21,622
hi d123,
Try this alternate method of potentiometer control, using the LTSpice potentiometer.
The 1st image shows the plots over the full range of bass & treble.
2nd image shows the centre and upper/lower limits of the pots.
E
Added: NE5532 sub and asy files.
38,909
Note that there's still a slight hump/droop at around 600Hz with the midrange settings of the pots, which don't occur with only one capacitor replacing C2 and C3.
dumbretard123
Joined Jun 18, 2024
22
hi d123,
E
Thank you!
Unfortunately the pots don't seem to work.
Found this tutorial though, so I might try that on my machine.
Unfortunately I don't have any admin privileges on this windows machine, so I can't add any libs.
dumbretard123
Joined Jun 18, 2024
22
Before I send this in for printing I want to make extra sure I didn't make any mistakes.
Pls tell me if I messed something up in the transfer from ltSpice to KiCAD1736154371096.png
