Interview Question -- Design a module that receives a Stream of 20MB/s...
swaviram
Joined Jan 25, 2022
7
Hey All,
I would like to get your help with the following question that I got in an interview and have not succeeded to solve it yet.
Design a module that receives a Stream of 20MB/s, with an input width of 8 bits (Byte).
The output stream should be 5 bits wide
+ Explain the problem, as you see it.
+ Share a diagram block.
+ Code (Schematic or Behavioural) that applicates the solution.
+ What is the rate of the output ?
+ What are the constraints or problems in this solution?
swaviram
Joined Jan 25, 2022
7
I have not had the interview yet.
I have it next week, but I really don't know how to start even.
I did not understand the probelm at all. I asked the interviewer for a clarification and he told me that the unit should convert between the formats (8 bit to 5 bit).
I feel like more info is missing. If someone could help me understand the problem so I could solve it, that would be great.
Ian0
Joined Aug 7, 2020
13,278
Don’t worry about vague questions. It means that you can answer your own interpretation of it, provided that you do answer the question as written and don’t contrive it too much as in this great Rowan Atkinson sketch.
So you could, for instance, split the input into 4-bit samples and output them at twice the speed, using the extra bit to indicate whether you are sending the top half or the bottom half
ericgibbs
Joined Jan 29, 2010
21,569
The output stream should be 5 bits wide.
hi swaviram
You could consider the question literally, it actually sounds like a 'trip up' question.
Infers a 8 Bit parallel input
Infers a 5 Bit parallel output
Loss of resolution by re-transmitting only the 5 High Bits
transmits a Stream of 20MB/s,
E
BobTPH
Joined Jun 5, 2013
11,647
I guess it is a trick question since I see it very differently than @ericgibbs . I assume he means ALL of the data is to be transmitted as a stream of 5 bits- wide. There is an obvious problem with doing that though, which leads to constraints.
Bob
ericgibbs
Joined Jan 29, 2010
21,569
hi Bob,
I mean, the 3 low order Bits are not retransmitted,
Basically 8 wide wire in and 5 wires out, retransmitting only the 5 high order Bits.
E
swaviram
Joined Jan 25, 2022
7
I'm really Junior, still a student...
How do I trasmit them at twice the speed? I understand the idea but how could I design it practically.
I'm lost here...
Ian0
Joined Aug 7, 2020
13,278
The trick is not to take my interpretation, but to interpret the question in a way you can answer it. @ericgibbs has a good suggestion on how to do that.
Is there an implication that no information should be lost? Or not?
Maybe you should be implementing some data-compression algorithm that keeps the same data rate?
It is unusual for parallel data to be transmitted with a fixed bit rate. It usually has additional lines to indicate when the data may be changing and when it is valid.
drjohsmith
Joined Dec 13, 2021
1,650
I would say
that the interviewer is wanting to see your design process,
can you identify the bits that can be ambiguous,
can you some up with suggestions
Its the sort of ill defined problem that one gets in engineering,
and an engineer will be able to "work the problem",
The fact your asking,
on a public forum ,
would suggest to me , that this might not be the job for you at this time
BobTPH
Joined Jun 5, 2013
11,647
Usually, an interview question like that is used to observe your thought pricess in tackling the problem, not even expecting an actual solution. But giving you the question ahead of time defeats that purpose. So, maybe it is intended to scare off unqualified candidates.
Bob
35,177
As others have pointed out, the purpose of being asked such a question in an interview is not to see if you have the correct answer.
There is no right answer. The purpose is to examine your problem solving and communication skills.
swaviram
Joined Jan 25, 2022
7
I would say
on a public forum ,
That might be true...
Even though, this position is for junior with 0 experience.
I have not solved problem like this one...
swaviram
Joined Jan 25, 2022
7
It's probably the same question sheet for all engineering roles .
I'd certainly expect a university student to be able to work through the problem
The problem is not well defined at all, and that's what made me very confused.
After asking for more clarification from him today, he said that I'm right and info is missing.
He said that the data indeed should be preserved after processing.
35,177
Pay attention. There is no acceptable solution to this question.
Hence, you make up your own scenario.
Try to think outside the box. Be a self starter and an independent thinker.
BobTPH
Joined Jun 5, 2013
11,647
It just occurred to me, if you wanted to ask a really devious interview question, giving it to him ahead of time, you could find one of the worst Instructable's out there, then word the question so that it comes up first in a google search. If they come to you with that "solution", they are disqualified.
Not saying that is the case here, just thought it was a good evil plan.
Bob
