I'm building a clock for 12 and 24 hour format. After setting the current time i need to run the clock. I need interrupt method to select either one of them. here is my way and can somebody tell me what I'm doing wrong? I use Codewarrior and C language. This is just part of the program that involves interrupts.
Also here is my vector.c file
Code:
#include "C:\Users\Lohitha\Documents\Codewarrior Data\HCS12Utilities\hcs12.h"
#include "C:\Users\Lohitha\Documents\Codewarrior Data\HCS12Utilities\delay.h"
void SetClk8(void);
void main(void) {
SetClk8();
//Enable Switches
DDRH &= 0xF0; // Set PH0 through PH3 to input
PIEH = 0x0F; // Enable Interrupts on PH0,1, 2, and 3
asm("cli"); // global setup
while(1);// wait here untill a push button is pushed
// This function enables PLL and use an 8-MHz crystal oscillator to
// generate 24-MHz E clock.
void SetClk8 (void) {
SYNR = 0x02; // set SYSCLK to 24 MHz from a 4-MHz oscillator
REFDV = 0; // "
PLLCTL = 0x60; // turn on PLL, set automatic
while(!(CRGFLG & LOCK));
CLKSEL |= PLLSEL; // clock derived from PLL
interrupt void rtiISR(void){
char value = PTH & 0x0F;
PIFH |= 0xFF; //clear Port H flag
if (value == 0x01)
//If push button 0 is selected do this
else if (value == 0x02)
// If push button 1 is selected do this
Code:
extern void near rtiISR(void);
#pragma CODE_SEG __NEAR_SEG NON_BANKED
#pragma CODE_SEG DEFAULT // Change code section to DEFAULT.
typedef void (*near tIsrFunc)(void);
const tIsrFunc _vect[] @0xFFF2 = {
rtiISR
