I thought they might have been reed switches too, but when I pass the magnet over the locations I can't see any physical movement, even under a 10x eye loupe?So those are reed switches. We are making physical electric contact in a gas tank.
Shocking.
That was my thinking. Pretty clever, and a solution to the old wire rheostat issues. But maybe it has its own issues.Very interesting system.
Just wondering about the TWO magnets? that's got me curious, is it doing some logical magic to create more measurement steps by using the two magnets?
Simple, and probably reliable... I wonder why they didn't use hall sensors instead of reed switches. Some reed switches can handle only very little current (I've seen some that can handle only less than 1/2 a milliamp), maybe that's why there are resistors connected in series with them.Looks like an 8-position sensor to me. The reeds are numbered up to 8. The spacing between reeds 4-6 is closer than for the other reeds; presumably to correct for the non-linear gas tank geometry.
The float has plenty of free play, no hint of sticking or rubbing of any kind that I could observe.KISS may have hit on something. The first fuel level sensor I used stopped reading the fuel level, the level was stuck at 3/4 tank. Long story short, the float that carried the magnet swelled and got stuck. I disassembled it and sanded down the float. I now have a spare fuel level sensor.
@wml52 How freely does the float move in the cylinder??
I purchased it from Summit Racing. They sell different sizes...........les, who was the original manufacturer of your dune buggy sensor? And have you seen this before?...............
Upon close inspection, it looks like a conformal coating. The sensor was removed after about 1 1/2 years in the tank. A little hard to tell. The opposite side, where the float slides, looks to have been masked off.........Is that crud on yours, part of the original coating?.......
