interfacing rf module with pic16f877
BMorse
Joined Sep 26, 2009
2,675
In order to get help, you will need to define quite a few things before anyone can even help, for starters....
What compiler will you be using to compile the C code?
What oscillator speed did you choose?
What modulation are you using for the RF? or are you using IR?
I could go on and on with the questions, but I think you need to elaborate on what you are trying to accomplish, and with what.
IMHO, You would be better off just using some off the shelf encoder decoder pairs, those can be used without programming Pic's, check out this site >>http://www.rentron.com/PicBasic/RemoteControl.htm they have all sorts of IR and RF modules along with encoder/decoders. No need to reinvent the wheel so to speak :)
