Hi friends im also facing same isssue with atmega 16a help me plzRight now I am trying a simple code of calling by GSM sim900 using atmega16
MY SETUP:Rx and Tx pins of atmega board are connected to Tx and Rx of my GSM modem and also to my uart bridge which i connect to my PC(done by splitting the Rx and Tx pins)-This was done so i could know whether my AT commands were given to modem or not
OBSERVATION;
AT commands appeared as i wanted in terminal(X-CTU I have Used) that means they were actually given to modem also(since i splitte the wires).But no call was made.However when i myself entered the AT commands During the same process I was succesful
MY code:
#define F_CPU 12000000UL
#include <util/delay.h>
#include <avr/interrupt.h>
#define BAUD 38400 //setting up baud rate
#define bd (int)(F_CPU/16/BAUD-1) //value of UDRR to be set
#include <avr/io.h>
void command(char*a) //function to send a string using pointers
int i;
for(i=0;a!='\0';i++)
while(!(UCSRA&(1<<UDRE)));
UDR=a;
_delay_ms(100);
flush ISR (USART_RXC_vect) //flushing any type of echoes obtained
char recdata;
recdata=UDR;
int main(void)
sei();
UBRRH=(bd>>8);
UBRRL=bd;
UCSRB|=1<<RXEN|1<<TXEN|1<<RXCIE;
UCSRC|=1<<URSEL|1<<UCSZ0|1<<UCSZ1;
_delay_ms(2000);
command("AT\r");
_delay_ms(2000);
command("AT\r");
_delay_ms(2000);
command("ATD+919933988118;\r");
_delay_ms(20000);
command("ATH\r");
while(1)
Can any one please help me why my atmega is unable to do so or is there any problem in my code?
Mod: Created your own Thread.E
Link to old thread.
https://forum.allaboutcircuits.com/threads/interfacing-gsm-sim900-with-atmega16.108047/post-998398
