And we know this because the periodic table gives us the weight of a mole of any element. One mole of hydrogen is clearly lighter than a mix of 80% Nitrogen and 20% Oxygen. The remaining components of air don't contribute much to a first order approximation.If a gas is compressed, then the mass per unit volume is increased. I would think that this would decrease the lifting power of hydrogen or helium.
How is the lifting power generated? Hydrogen is significantly lighter than air, and hence will float in a pool of air, like a cork in water. Compressing it will increase its weight or unit volume making it less lighter than air, thus reducing its lifting power.
The ideal gas law is often written as:Hm...that makes sense. Hydrogen is lighter, because of its less density?
When we made air hot, that also will be light and can lift things (I guess hot air balloon for human lifting use hot air/fire flames, instead of Hydrogen). Can I say "hot air has less density (spread atoms far) than cold so it's lighter"? Or the heat is related to Gravity too?
At sea level and 15 °C, air has a density of 1.225 kg/m^3, while aluminum has a density of 2.6 x 10^3 kg/m^3. That ratio explains why air is transparent to visible light and a block of aluminum is not.Hi, so nice information! Then there's no direct relation of gravity there.
As you said if temperature increased then volume also will be increased which means density becomes less and thinner. Gas is not visible, is it due to its extremely less density?
If a child asked me 'Why I cannot see the air' then what I could say? What I need to understand?
So why is glass transparent while chlorine and many other gases are not?At sea level and 15 °C, air has a density of 1.225 kg/m^3, while aluminum has a density of 2.6 x 10^3 kg/m^3. That ratio explains why air is transparent to visible light and a block of aluminum is not.
Because color is a function of allowed transitions of electrons (the molecular equivalent of band gap in a semiconductor material). If an allowed transition (absorption) is in the range of a visible photon, the material will have color. Color can also be caused by fluorescence (emission) from a molecule after it is excited by a non-visible (UV) photon. Chlorine has empty anti-bonding orbitals very close in energy to the non-bonding (lone pairs) and can be excited by low energy of visible light (absorb specific energies of visible light) to give it the unique color. Other molecules like nitrogen require lots of energy to move electrons to the next available empty orbital (in the deep UV).So why is glass transparent while chlorine and many other gases are not?
You didn't read the context very well. Your explanation would be a lot more useful as a response to Papabravo's post.Because color is a function of allowed transitions of electrons (the molecular equivalent of band gap in a semiconductor material). If an allowed transition (absorption) is in the range of a visible photon, the material will have color. Color can also be caused by fluorescence (emission) from a molecule after it is excited by a non-visible (UV) photon. Chlorine has empty anti-bonding orbitals very close in energy to the non-bonding (lone pairs) and can be excited by low energy of visible light (absorb specific energies of visible light) to give it the unique color.
Because that was so far off I didn't know where to start.You didn't read the context very well. Your explanation would be a lot more useful as a response to Papabravo's post.
Interesting Uses for Quantum Computing | General Science, Physics & Math | 0 | |
Stats problem that some might find interesting. | General Science, Physics & Math | 41 | |
Interesting reminder about capacitor safety | General Science, Physics & Math | 3 |
