Hello Folks!
I have acquired a damaged front load washer and a have pulled the 3ph 16K RPM Motor and controller. with some research and testing i have determined all the wire functions. and have successfully bench operated the motor and have even run the spin cycle. pretty cool motor with lots of potential, and lots of speed. i have read the data sheets for all the major ic's and am now familiar with the pcb component layout. what i want to do is tie in a serial port so i can modify the program on the ADMC326. my current objective is to make the driver actively user controlled. if i could start with velocity and direction control. my 2 current road blocks are: i am unable to definitively figure out the proper serial pins on the ADMC326. it does state that pins #2 - #7 are serial pins. but which are which? i am not much of a programmer, i would need some guidance in that area. would you need some kind of eeprom program or something? maybe i could build a small analog converter circuit to directly feed the ADMC326 instructions? an analog conv. to frequency to feed PWM Driver. maybe just modify the spin program already there. maybe it would be easier to just build a new driver. the answer seems to be right in front of me but i can't see it. throw me some ideas.
IC Data Sheet Links:
ADMC326 - http://www.analog.com/media/en/technical-documentation/data-sheets/ADMC326.pdf
74HC165 - http://www.nexperia.com/catcher/74HC_HCT165.pdf?
74HC14 - http://www.ti.com/lit/ds/symlink/sn74hc14.pdf
IR2136S - http://www.infineon.com/dgdl/ir2136.pdf?fileId=5546d462533600a4015355c8a02116a5
