Inserting new posts over old ones
Wendy
Joined Mar 24, 2008
23,800
OK, I think all the regulars have seen my thread LEDs, 555s, Flashers, and Light Chasers. I have several new chapters I want to write, but have run out of room again. Far as I know I'm stuck, it if gets full I just have to continue the section at the end of the thread.
I can't use blogs for this because they do not allow displaying attachments on the comments (which includes the OP comments). There is a bit of a hole here, from what I can see.
The only solution I can see, and it isn't really a solution, is to delete other peoples posts so I can modify existing ones.
If there was a way to change the time date stamp on a new post, and then ask a mod to insert it that would be good too, but I don't think it is possible at the moment.
bertus
Joined Apr 5, 2008
22,970
Hello Bill,
Would it be an idea to have a section where only senior members can post?
In that way there will be room for submissions.
This submissions area could be made in the circuits and projects section.
I think the other senior members will respect the submissions.
You are doing a great job on them.
Greetings,
loosewire
Joined Apr 25, 2008
1,686
Bill, check out how old are you on off topic,It has 150 entries check it out
maybe moderator can give more space to continue,check it out.
