Hi all, this is my first thread on this forum. I've been popping in here quite a few times now, a lot of useful info can be found here.
There's something I couldn't find any info about in a form that I could understand, haha I'll need some help with this...
Ok, so I'm building a motorcycle. Small 125cc project. I've decided to use a supercapacitor bank to enable the bike to start from an electric starter motor. (it has kickstarter too, so not a problem if the pack goes flat). I went this route mostly because normal battery would ruin the look of my project, supercaps are nicely hidden away.
So, I've got a single row of 500F 2.7V capacitors (x6), each one has overcharging protection PCB on top. This is sufficient to start the bike, no problem.
I need a solution to slow down the current going into the capacitors in case if they go flat. The bike has a kickstand but if the pack is flat it will draw all the power and the bike won't start. I've been reading about inrush current limiters etc but electronic components are a bit like black magic for me.
Also I was thinking about diodes... Do I need them on the circuit? My understanding of electronics is very basic so every help would be appreciated. If there is a ready made solution on the market that would be great as my soldering skills are even worse!
The bike: Yamaha YBR125
Capacitors: row of 500F 2.7V capacitors (x6 so ~83F ~16V)
Max amps on the bike would be 15A (according to the main fuse on the bike)
I'm attaching bike's original electrical diagram. My supercaps would be replacing the battery.
Thanks!
Thanks!
