inrush current
danielmoham
Joined Oct 24, 2017
we have a double pole relay in our dc-dc output, due to the load with caps, we have a huge in-rush current. So the circuit is boost and after the output cap, we have a double pole relay (close/open +, and close/open - at the same time). The relay is turned off at first and it gets turned on. what type of circuit can we use? 1200V rated voltage, I don't think we have PMOS @ 1200V. Usually, the in-rush current is discussed at the input side and not in the output side. Any help is appreciated.
twohats
Joined Oct 28, 2015
617
More info is required, you could be talking about almost anything.
My reply is hopefully to get you some meaningful answers to your problem.
good luck............
