Input Line Reactor
pujulde
Joined Jul 24, 2013
111
Three phase motor is driven by VFD and using input line reactors. What is the use of reactors ? Is it for reducing the instantenious current increment? And what if I bypass them?
Thanks.
MaxHeadRoom
Joined Jul 18, 2013
30,806
It is intended more for power factor reason than anything in the VFD itself, For my money, if you have one I would rather use it on the output side, it makes it easier on the drive and the motor, especially if the later is not vector rated.
Max.
BR-549
Joined Sep 22, 2013
4,928
Where is it using input line reactors? Input of what, VFD or motor? How old is the equipment? Is there anything else connected to reactors?(other than input and output)
Edit: What is the load/function of the motor?
MaxHeadRoom
Joined Jul 18, 2013
30,806
Typically manufacturers recommend a 3phase choke or reactor either on the 3ph supply side or the output side between VFD and motor, or both.
I've never used one on the input, the VFD input usually consists of a 3ph rectifier and large capacitor bank.
Max.
