scubasteve_911
- Joined Dec 27, 2007
- 1,203
Hi ,
Here's an image that should clear up your confusion. You don't need an inverter for it to work, that was basically used to invert the signal and to give a buffer. The output of the impedance of that circuit was 10K, which was a bit much. That resistor value needed to be adjusted for different photodiodes.
I would use a packaged solution, like the part I originally pointed out. Hook it up as the picture shows. Calculate the values of the current limiting resistor to the LED as instructed, along with the pullup from the transistor. This is probably the simplest solution. The only thing I would add-on, in your case, is a MOSFET as a switch. This will give you more power handling.
http://www.electronics-tutorials.ws/transistor/tran_7.html
Steve
PS- You aren't dense, you're just new. I knew a guy in 4th year university that didn't know how to hook up one of these sensors..
Steve
