Infrared Beam Sensor
Reloadron
Joined Jan 15, 2015
7,946
Referencing the circuit in post#17, I wonder if that "COM" terminal is tied to other than the relay contact common. Why else would the assembly have the two supply terminals AND a common terminal??
Post #17 only reflects two supply terminals (+ and -). The image shows the transmitter and the receiver, two separate units. Transmitter + and - and receiver + and -. The Com and Out are just a switch and in the drawing they tie switch Com to power - or ground. That is an external connection so in the example they switch Com.
Ron
Dadu@
Joined Feb 4, 2022
155
Ok, In this case what would be logic value on MCU pin when object is detected? what would be logic value on MCU pin when object is not detected?
