Infrared Beam Break Receiver
12,251
5.8 kHz is less than one octave above 3.8 kHz so there is some signal attenuation in the filters. If the range is not what you need, some receiver components can be adjusted.
Plamen
Joined Mar 29, 2015
111
Also the light emitter must be modulated.
A constant light source will not work.
Petkan:
Very appropriate suggestion (to modulate the transmitting LED) as to suppress effect of background light changes.
To improve robustness people even tune the receiver (i.e. make it narrow frequency band) to the light modulating frequency.
spike1947
Joined Feb 4, 2016
537
Hi All
I would just like to say a BIG thank you to everyone who has helped me with this project ( and others ) , I would of been at a loss without all your help .
again thank you
spike
spike1947
Joined Feb 4, 2016
537
Hi again
Just a quicky on this project , could I use a 2N3904 Transistor in place of the BC547 ! , and why the Base on the BC and a Gate on the 2N ! .
BC547 -
Voltage rating: 50V
Maximum current: 0.1A
Power rating: 0.5W
Frequency range: 300 MHz
2N3904 -
Voltage rating: 60 V
Maximum current: 0.1 A
Power rating: 0.625
Frequency range: >250 MHz
Amplification (B): >100
cheers
spike
spike1947
Joined Feb 4, 2016
537
Hi
Sorry confused the BC547 Transistor for a PNP , apologies .
cheers and thanks for your reply
ps: eric where in Yorkshire did you come from ! .
