- Joined Jul 18, 2013
- 30,815
If you have obtained this new or otherwise unused, why do you need to check it?I am a hobbyist and I wanted to use encoder in a project so just checking it
so I don't have the option to check it manually so I think I have to test it c program
Checking an encoder of that resolution you are going to be hard pressed to see individual pulses, you should see a fluctuating voltage however, most modern VOM's are very slow reacting.
What do you intend using it on or inputting it to?
