In loop compensation of an operational amplifier - advice on SPICE simulation results
Makadamij
Joined Aug 23, 2018
12
my goal was to design a constant current source for driving a LED array with the use of an input/output rail-to-rail operational amplifier (TLV2374) with 5V single supply. I went for the simplest design I could find, namely a unity gain bufffer, whose output is connected to the gate terminal of a logic level MOSFET (IRLZ44N). Voltage signal that is being fed to the non-inverting input is in the form of a sinusoidal PWM signal with carrier frequency of 44100 kHz and a logic high of 5V. The potentiometer enables changing the current through the LED from 1V to 100mA by the use of a sense resistor of 0.5Ω. A scheme of the circuit is shown below:
Unfortunately, at that time I thought this to be a failproof design and hence did not do more research or detailed simulations. When it came to PCB assemblying and testing, I found the circuit to be very unstable, with significant peaking during transient step response and subsequent oscillations being present.
I found this to be due to reduced phase margin, caused by the capacitive loading of the MOSFET, which, according to the datasheet has an input capacitance of 1700pF, while the op-amp can handle capacitive loads of max. 10pF without the need of additional compensation. I then have searched for compensation techniques and went for the circuit depicted below:
If my understanding is correct, the isolation resistor Riso, combined with the feedback capacitor Cf and resistor Rf, forms a bypass for the high frequency signal and therefore prevents phase margin decrease. Furthermore, I simulated the non-compensated and compensated version of the constant current source in LTspice to determine the change in phase margin. The results are shown below:
The compensated circuit shows no peaking or oscillation and has a phase margin of 50°, which is satisfying, however the simulation has been done with a sinusoidal AC signal of amplitude 1V instead with PWM signal. Would it therefore be a better idea to further increase phase margin or is the compensated circuit already good enough for production?
Thank you for your advice!
Edit: Provided LTspice simulation files and model files for op-amp and MOSFET
38,909
A transient simulation with a step input between two current levels, will show the stability.
There should be no significant overshoot or ringing at both step output transitions.
Also you need to bias the circuit at some output current for a normal DC bias setting to get a proper AC simulation.
Your sim shows a zero current setting.
As a nit, you don't need to show all the ground connection symbols at the bottom of the schematic, as it just makes the schematic more cluttered.
38,909
Below are the LTspice simulations for a circuit similar to yours:
They show results for two values of C3, 0.4nF (green trace), and 1fF (essentially zero, yellow trace).
I tweaked the values of C3 and R2 for best transient response.
That usually gives a Bode plot with no peaking and good phase margin.
Since the AC bode sim uses linear models, but the transient sim uses more accurate, non-linear models, the transient sim usually gives more accurate results when adjusting for stable feedback loops.
I have circuits where the Bode plot looks like the circuit should be stable, but the transient response showed significant instabilities or even oscillations.
Note the overshoot/ringing in the transient waveform, and the peaking in the Bode plot for the case with essentially no (1fF) C3 compensation.
28,488
We are missing something here: "my goal was to design a constant current source for driving a LED array" does not tell us just what the LED ARRAY is to be driven with. Is it a DC current, or is the goal to deliver a " a sinusoidal PWM signal with carrier frequency of 44100 kHz "???
Those are two quite different drive signals indeed. Either one may be possible, but the circuits will be a bit different.
