I need to add a button that will change the mode from 24-hour to 12-hour. I have made the 24 clock with ripple counters (modulo-10, modulo-6 & modulo-3) and that works fine. I also know I need to use a multiplexer here so the select line will be the input of the button. However, I am having a hard time converting to 12 hour mode. Also with the help of 7 LED-segment, I also want to show if it is AM or PM so show A or P.
