Implementing hex flags
Samantha Groves
Joined Nov 25, 2023
162
Suppose we have a circuit which adds 2 Hex numbers lets say A+F and stores the result in another register.In binary form it is easy to implement the carry,overflow,zero and negative flag however in hex what would be the equivalents.Im using 4 bit registers and I dont have access internaly to the register which means I cannot calculate these flags bit by bit.
Now that I have thought this thru the carry flag is easy to implement because it is very similar to the case of binary but the others are not very well thought out.
Thanks for your help!
35,173
Hex and binary are same thing, i.e. they are both four binary bits representing the same thing.
F = 1111 = 2^3 + 2^2 + 2^1 + 2^0
Samantha Groves
Joined Nov 25, 2023
162
Well yes thats true.But here is my issue.To get the overflow flag of a 4-bit binary adder you need to know the carry and the sum of the MSB and XOR them however now we only have 2 Hex digits(I cannot access bit by bit the register)so which circuitry must I connect the 2 HEX digits to get the overflow flag?
35,173
Ignore the fact that you have two hex digits. Treat them as two 4-bit binary values.
value 1 = DCBA
value 2 = dcba
Simply add the two together as DCBA + dcba.
The result is a 5-bit binary value.
22,111
value 1 = DCBA
value 2 = dcba
Isn't that going to be 16 bits plus a Carry flag.
boostbuck
Joined Oct 5, 2017
1,060
Suppose we have a circuit which adds 2 Hex numbers..... .Im using 4 bit registers....
If you adding using 4 bit registers then you are using binary, even if you prefer to interpret the values using hexadecimal symbology.
The addition using hexadecimal would be using 16-value logic rather than 2-value in binary, but it follows the same rules as binary (or any other base for that matter) when dealing with carry and borrow.
neonstrobe
Joined May 15, 2009
200
value 1 = DCBA
value 2 = dcba
Well, is that not the problem? With a 4 bit register, you don't have 5 bits to play with.
Unless some additional logic is added to specifically handle the carry then it may be necessary to check "manually" by testing the two values to be added and generating a third 4 bit number when overflowing.
35,173
When you add two 4-bit values, you can expect a carry when the sum is greater than 1111. The carry is the 5th bit.
For example, 1111 + 0001 = 10000.
33,186
What, exactly, DO you have access to? Don't say "two hex digits", because that is going to be taken to mean that you have access to a total of eight signals -- four binary signals for each hex digit.
