Implementing Boolean Functions Using 2x1 Multiplexer
Status
Not open for further replies.
Durton
Joined Jan 5, 2017
I have the Karnaugh Map below and I need to implement it using a Multiplexer which has a1 as the select line, hence I would need a 2x1 Multiplexer if I'm not wrong.
My problem is that I don't know how to group the ones together to find the implicants in this case, I tried as you can see from the picture I uploaded but I don't know if it is any correct.
I would appreciate it if someone could help me figure this out, thank you in advance.
RBR1317
Joined Nov 13, 2010
715
If A1 is the select control, then instead of one logic function of 4 variables A0,A1,B0,B1 to implement there will be two logic functions of 3 variables A0,B0,B1 to implement. So minimize the blue & yellow K-maps separately, then select between them.
Status
Y Wireless & RF Design 0
