Impedance matching transformer
Exjay
Joined Nov 19, 2015
196
Hello mentors,
Please I am building on my basic in electronics. Now, I have reached a chapter to learn to match impedance using transformer. So the material needed is a small impedance matching transformer approximately 600 to 800 ohms and 4 to 8 ohms speaker. Can someone tell me how to get or build the special type of transformer since I can get it here in the market.
Audioguru again
Joined Oct 21, 2019
6,826
Amplifiers used input and output transformers about 70 to 80 years ago.
Most amplifiers that can drive an 8 ohms speaker can drive a 4 ohms speaker with a higher output power.
28,407
All of the equations remain the same for basic electrical circuits. The laws of physics relationships do not change. Of course, new devices arrive and the frequencies able to be used continue to increase.
But the circuit analysis, the relation of voltage and current and power have not changed. Likewise, the effects of inductance, capacitance, and resistance are still the same. So the basics that applied 50 years ago still all hold.
What does change are the available components, both the passive devices and especially the active devices.
Especially the programmable logic systems, including the processors. And in that area, along with the constantly advancing abilities, comes the ability to have program bugs that are more subtle and much more challenging to deal with.
The usefulness of transformers remains, although alternatives have been created that in many applications are suitable replacements. The primary drive towards avoiding transformers has been the cost and size. While other components constantly shrink, transformers have not been economically following the trend so much. And for convenient impedance matching with isolation and power handling ability, the alternatives are not nearly as convenient.
Exjay
Joined Nov 19, 2015
196
I want to thank you all for your response. Nonetheless, I cannot order the part in the link because they don't have store here. What old appliances can I get them from?
Ian0
Joined Aug 7, 2020
13,288
100V-line public address speakers between 10W and 20W.
28,407
Audio output transformers are usually single-application items used in audio amplifiers. Ten to 20 watt units would be found primarily in much older tube-type audio equipment. They will probably require rewinding the primary side to be useful with transistor circuits.
Ian0
Joined Aug 7, 2020
13,288
Valve amp output transformers are typically between 4kΩ and 10kΩ on the primary side. A lot more than the TS's target of 600Ω to 800Ω.
Some of them are gapped to work with a standing DC current.
28,407
That is exactly why I commented: " They will probably require rewinding the primary side to be useful with transistor circuits. " (Clearly stated in post #11)
Externet
Joined Nov 29, 2005
2,678
"What old appliances can I get them from? "
Usually from this kind of deceased junk :
And highly probable from inside a 120 to 12 V :
Audio impedances are referred to 1KHz. Read carefully; impedance is one thing, resistance is another.
Ian0
Joined Aug 7, 2020
13,288
Any transformer with a ratio of √(800/8) which is 10:1 will do, provided that it has enough magnetising inductance to manage the lower end of the frequency response, and low enough leakage inductance to manage the higher end.
So a 120:12 transformer would do the job, in theory. If it were rated for 60Hz. As magnetising inductance varies inversely with power, a lower powered transformer would have better low-frequency response (and worse high frequency response).
Most mains transformers have an adequate response at 1kHz, though it might be pushing it a bit for split-bobbin types.
28,407
It is not likely that any of those devices have audio transformers able to handle even one watt. And the TS was specific: ten to 20 watts.
If the TS was nearby I could give them a 100 watt output transformer from a BOGEN PA amplifier. But shipping to the TS listed address would be terribly expensive. Probably Digikey would sell it but again, the shipping will be the problem.
an explanation of the actual purpose may lead to an alternative solution being found. so I suggest that the TS explainthe goal of the search.
Danko
Joined Nov 22, 2017
2,238
Oh, I see...
Hubtecs Electronic Component Store
Electronic parts supplier
Address: 315 Herbert Macaulay Wy, Yaba, Lagos 101245, Lagos, Nigeria
+234 813 501 0778
New Nigeria electronics
Address: 135 MOHAMMED MUSTAPHA WAY JIMETA YOLA, ADAMAWA STA#TE, Jimeta 640102, Nigeria
Ibekwe Electronics Nigeria
Address: Shop F2,Ogbete Main Market, Nigeria
+234 803 713 4624
Uncle Laga Nigeria Enterprises
Address: 28,Odelemo Road, Nigeria
+234 802 389 5772
Flamingo Electronics and Multi-Purchase Store
Address: F3WJ+JQV, Umuoba Uratta Rd, Ikenegbu, Ihitta 460104, Imo, Nigeria
Ganic Electronic Nigeria
Address: Block B33, Oshodi Main Market, Oshodi, Oppsoite Shop No. C8, Lagos, Nigeria
+234 803 552 8769
Service options: Offers same-day delivery
Nnabest Electronics Nigeria
Address: 54 Abakpa Nike Rd, Isowopo I 342101, Ondo, Nigeria
+234 703 534 9741
Authentic Power Nigeria International
Address: 33,New Market Road, Nigeria
+234 806 097 9679
Uba Na Bombey Nigeria Limited
Address: Blk 4, Shop 9,Akeju Shopping Complex, Nigeria
+234 805 467 8305
Blessed Wisd Chibuzor Electronic Nigeria
Address: Oshodi Main Market, B14 Opposite A19, Oshodi, Lagos, Nigeria
+234 703 512 2339
Onyisco Electrical Nigeria Service
Address: 2 Cooke Rd, Avbiama, Benin City 300102, Edo, Nigeria
+234 803 067 9445
Sole Electrical Nigeria Limited
Address: 21 Tatlow Road, Ezinihitie Mbieri 461121, Imo, Nigeria
+234 803 395 7886
Kenelectronics Nigeria
Address: 105,Adesuwa Grammar Road, Nigeria
+234 815 306 2217
De Onward Nigeria Limited
Address: 4/5 Ahmadu Bello Wy, Kado, Mobushipe 900108, Federal Capital Territory, Nigeria
+234 803 370 7915
OBINWANNE & PURITY NIGERIA
Address: C1-12 Arena mkt oshodi, Lagos 300001, Nigeria
+234 803 528 0202
28,407
OK, there you go!! A whole bunch of distributors.
The great thing about these forums is the vast resource of knowledge and experience that is available.
