Is there a way to fix this? I don't own a soldering iron, so I stumped on what to do.
Ok, I figured from what I read online that a hot glue gun wasn't going to cut it. So how do I repair traces? Isn't that a piece of wire that you solder on both sides of the broken trace?Seems like some traces also broke. Personally, I don't see a possible way to fix this without a soldering iron.
Ok, I'll look into this. Thanks for your help.I have seen (but never used) products like this
But, honestly, just find a soldering gun or someone with one that has some experience soldering (if you don't).
But, honestly, just find a soldering gun or someone with one that has some experience soldering (if you don't). Traces can be repaired by soldering and copper tape, which I have done successfully. Lots of folks on here who can also advise you.Ok, I'll look into this. Thanks for your help.
Alrighty, thank you very much for the info!But, honestly, just find a soldering gun or someone with one that has some experience soldering (if you don't). Traces can be repaired by soldering and copper tape, which I have done successfully. Lots of folks on here who can also advise you.
