If not WD40, then what?
djsfantasi
Joined Apr 11, 2010
9,237
WD40 (Water Displacement formula#4o) is not a lubricant. It gets gummy over time.
I've read that several times. Lubricating oil also becomes gummy over time.
Then what do you use for lubrication?
PS., I use liberal amounts of WD40 to clean out gummy oil, then re-oil the bearing.
#12
I used Hoppes Gun Oil for years because it has no varnish. Then the latest fractional HP motors changed to a different bushing and it is so tight that Hoppes oil bursts into flame. Next up is transmission fluid because my teacher described it as a good grade of oil with some red dye and a LOT of detergent. Other people here use SAE 20 motor oil.
jpanhalt
Joined Jan 18, 2008
11,087
It is said that unlike plain lubricating oils, WD4o had unsaturated oils in it -- some suggested it was just fish oil. Those oils are known generally as drying oils (http://en.wikipedia.org/wiki/Drying_oil ). Another good example of one is linseed oil. They polymerize eventually to a thick goo or even a hard paint. Pure mineral oils, like spindle oil, do not undergo the same reaction (http://en.wikipedia.org/wiki/Spindle_oil) .
Two keys to WD-40's success was marketing and the perfume used in it.
John
Dr.killjoy
Joined Apr 28, 2013
1,196
Mobile 1 motor oil or high speed bearing oil..WD-40 stands for Water Displacement Not bearing lube lol.. Alot of people use wd-40 on guns and such.. Then over time the liquid turns into a gummy substance to displace the water which was the origional design and wd-40 also states its for light lubrication... So IMO bearing lube is a no go.
cmartinez
Joined Jan 17, 2007
8,786
You haven't mentioned what it is that you want to lubricate. There's a whole universe of highly specialized lubricants out there.
djsfantasi
Joined Apr 11, 2010
9,237
Thanks everyone.
No one mentioned 3 in 1 oil? Is that because it's lifetime is short and it too turns gummy?
I used to resurrect discarded floor fans. Most of the time, all it took was to clean up the motor, flush the bearings with WD-40 until the fan started turning, and finally add 3 in 1 oil. They would last a year when they'd be replaced with new fans resurrected from roadside trash.
I'd use motor oil after this thread, but practically it probably wouldn't extend the life too much, because of bearing wear. But using motor oil is my take away.
cmartinez
Joined Jan 17, 2007
8,786
Thanks everyone.
For bearings, I too use WD-40 to clean them up, but then I lubricate them with a graphite-based sprayable lubricant.
#12
Exactly!
My MTBF is 7 years and I won't let WD-40 or 3-in-one on my truck.
