Identify burned part of Tacx Flux Direct Drive Smart Trainer
twistedhype
Joined Jun 13, 2020
I want to know the burned part?
My Tacx already out of warranty, so I want to replace the burned part my self.
Please identify of the burned part. Picture Attached.
Thank you.
Burned Part
Board after removed burn part
whole board
Front of the burned part
Back of the burned part
sagor
Joined Mar 10, 2019
1,049
It seems to be a resistor (R86). However, without being able to read the markings, or without a schematic, no one can say what the value is. Also, for a resistor to go like that usually means some other component when "short circuit" or overload, and caused the high current to flow thru the resistor. Thus, I suspect there are other components that are damaged to start with, the resistor was a result of other components failing. (or did you plug it into the wrong power source?). Also, check the fuse next to the resistor, it may be blown as well.
Good luck.
eddwhatley
Joined Sep 16, 2014
5
Sir twistedhype
Is this unit now having a BIG pile of dust on it . . .with no ensuing activity in the interim ?
Whassamattahyou ? . . . look at the CORRECT identifier and accompanying techno symbol beside it . . . its a varistor. . . . .
It is across the incoming AC line and if you are using 220-240VA power . . . . use a properly high enough
rating such that incoming / constant power spike " nibbles " don't untimely wear it down.
Consider . . . .
https://www.digikey.com/en/products/detail/panasonic-electronic-components/ERZ-VF2M431/672908
73's de Edd . . . . .
Did you hear about the $3 million West Virginia State Lottery? The winner gets $3.00 a year for a million years.
