Hi, Guys, Would you please help to identify the SMD.@MrChips
designator Q16, it's from the Nividia Shield pro set top box.
this smd is right behind the 19v DC input port. marking code 1050C. it's shorted, need replacement, but would like ask for help to identify the replacement part. the current measure on pin 1-6 (anti clockwise )to ground is:
1. 1.2 ohm
2. 1.2 ohm
3. 10k ohm
4. 25M ohm
5. 1.3 ohm
6. 1.3 ohm
this board has earlier version using marking code 10552, new version using marking code 1050C, see pictures.
1. 1.2 ohm
2. 1.2 ohm
3. 10k ohm
4. 25M ohm
5. 1.3 ohm
6. 1.3 ohm
