ic for motor driving
yousufsaleem
Joined Sep 28, 2011
16
which ic i can use to drive 2 motor .............if i have conditions
both running in forward together
one running while other is in stop state
both are stop
plz reply
and plz provide schematic if any one have it
panic mode
Joined Oct 10, 2011
5,205
this is VERY vague question, just like
"which medication can be used to heal? provide detailed treatment if possible."
and answer is - it depends...
motor can be many things so you need to say more about it (stepper, DC, AC single phase, AC three phase, voltage, power etc).
be80be
Joined Jul 5, 2008
2,395
Yep it would help to know what kind it's a big world out there with all kinds of motors.
You could use just a NPN or a H-bridge or a AC 3 phase controller and on and on
If you are using DC Motors runs on 1A-4A your best bet is the L298n Motor driver IC. It has embedded H-bridge circuit. For lower Amps you can use L293 Motor diver IC.
The circuit diagram for Motor driver with L298n Motor driver can be found here
http://www.myplogger.com/backyard-2
If you are using AC motor, you can use a motor starter. Companies such as ABB, Mitsubishi, and Schneider Electric sell Motor starters and controllers. You can then feed your pwm signal to these controllers or you can use communication bus such as CAN
