IC 555 self trigers
IC triggers without pushing the button?I have made the circuit on a pcb?Possible errors?
  • circuit design error
    Votes: 0 0.0%
  • personal error(soldering 2 points short,etc...)
    Votes: 0 0.0%
  • components error
    Votes: 0 0.0%
  • Total voters
AlbertHall
Joined Jun 4, 2014
12,663
Both the trigger and reset inputs operate when pulled to ground so these inputs should have a pull-up resistor, say 10k, to the positive supply and the switches between those inputs and ground. Note that if the trigger input is held low for longer than the monostable period then the output will remain high until the trigger is removed.
AnalogKid
Joined Aug 1, 2013
12,300
You don't say what you want the circuit to do and when, you mention a pc board and ask if there is a wiring error, but don't show the board or the completed assembly.
Exactly what is your question, and why do you expect an answer when you have provided no information?
ak
dl324
Joined Mar 30, 2015
18,524
Welcome to AAC!
When is the timer self triggering? At power on?
Edited schematic that's easier to read:
Redrawn circuit:
This circuit won't work. Trigger input must go below 1/3VCC to trigger the timer. Reset is LOW active, so the reset switch has no effect.
