In I2S DAC application, most datasheets specifies timing among LRCLK/BCLK/DATA. Without MCLK alignment?
http://www.ti.com/lit/ds/symlink/pcm1754-q1.pdf
datasheet above as an example, MCLK here is named as SCLK in this datasheet.
Page13 specifies the SCLK frequency, page15 specifies timing among LRCLK/BCK/DATA, you can see the relationship of these 3 signals, but no SCLK.
It means there is no difference if I connect DAC's MCLK to signal source's MCLK_OUT or a crystal?
If yes, what make it no difference?
Thanks for reply.
Thanks for reply.
