To create the count up/count down timer, I believed that my original clock was already a count-up timer that could be set to any time and be changed accordingly. In my attempt I decide to make a countdown clock with the counters I originally had all counting down. I then decided to join these counters with my clock that counted up where the user could choose whether or not to use the Count-up or Count-down clock. I put the outputs of each clock’s digit into a circuit with a multiplexer and a switch. I believed that the switch would allow the user to switch between both clocks/timers. However it only allows the user to switch to a count-down timer that will countdown with no regards or relation to the Count-up timer/clock. I do not know how to fix this error.
