I or E ?
Gator325
Joined Jun 19, 2020
Our Navy RBB and RBC receivers use a 6-8B current regulating tube to maintain a stable oscillator.
These are getting rare and expensive to find.
One solution offered is a 20 ohm 10 watt resistor in a tube base to replace the tube.
Another is to make a simple voltage regulator circuit in a tube base.
Since the original tube was a current regulating device, would a resistor or voltage regulator do the same job?
schmitt trigger
Joined Jul 12, 2010
2,290
The problem with a simple resistor is that the current varies linearly with the voltage differential.
You have not mentioned what is the supply voltage, but this could be very likely duplicated with a solid state circuit, consisting of a Mosfet and suitable control circuitry.
EDIT: I read about these tubes. It is a resistor with a positive temperature coefficient. That would suggest a PTC thermistor, but the thermistors usually have a very sharp transfer characteristic, while the tube's datasheet indicates a very wide flat area.
So the solid state solution may be the best option.
AlbertHall
Joined Jun 4, 2014
12,663
They do regulate current not voltage and can work equally well with AC or DC. Making a DC constant current source is not difficult and with a bridge rectifier this could handle AC too.
The Amperite automatic current regulator is a reliable current regulating device, which
can maintain a constant current in a circuit over a very wide range of input voltages. It
consists of a resistance wire with a positive temperature coefficient of resistance,
hermetically sealed in a bulb containing hydrogen or helium gas. The resistance of this
element will automatically increase or decrease in accordance with the change of
temperature in the unit to maintain a very accurate current level.
