I need help with laplace transform
rd572
Joined Nov 27, 2017
Good day.
I have problem with a laplace transform.
I want the IR(s) back to time domain. Current starts with 0[A] and the SW will close at t=0.
I have tried calculating for several times but I get the wrong answer
(2/3)*E*L( 1-exp( -(3R/2L)t ) )
for all attempt.
I want to know how to return IR(s) to the time domain.
thank you
wayneh
Joined Sep 9, 2010
18,146
Good day.
for all attempt.
thank you
You will likely get more feedback if you show your work so far.
rd572
Joined Nov 27, 2017
First, thank you for the reply.
And about my work so far. I`m so sorry that I got the correct answer when I tried again this morning.
Thanks for the reply and advice about using this forum.
WBahn
Joined Mar 31, 2012
33,118
Be sure to sanity check your answer.
You know by inspection what the initial and final currents are. Be sure your answer agrees with that.
You should also be able to write down the full solution inspection for a circuit like this, so be sure to compare that to your answer and make sure they agree.
