I need a specific IC that works as a toggle switch
AnalogKid
Joined Aug 1, 2013
12,265
Not bad, but not great. Looks like a pin-for-pin drop-in equivalent to the part in post #17, but with a bit worse performance.
2 ohm flatness in a 75 ohm circuit is almost 3%. This will show up in the switched signal as differential gain. Not a full 3% DG, but probably around 1%. Compare this to a mux designed specifically for video, which will come in at less than 0.1%. Also, the off isolation will be higher.
In a part like this, the actual switch circuit usually is a single p-channel MOSFET in series between the in and out pins. In a true video mux part, it is three FETs (2 p-channel, 1 n-channel) or bipolar transistors in a T arrangement. The shunt leg is where the way better off-isolation comes from.
Here is a true video switch for comparison. Note that this part also has the output cable drivers built-in. That is a big advantage, as often the performance of a great switch is degraded by the output amplifier pc board layout.
https://www.analog.com/media/en/technical-documentation/data-sheets/AD8188_8189.pdf
You are 20-30 years too late with this question. Back then, Maxim had a pile of video-specific chips, including many configurations of muxes, that were fantastic. Geezers who designed video circuits in the 70's still drool over them.
ak
spikespiegelbebop
Joined Nov 30, 2021
163
ak
Sorry, I forgot I wasn't born by the time.
