I have a problem with my 1st project build, a clock
RichardO
Joined May 4, 2013
2,270
Start by looking at the solder connections along the trace that goes to the bad segment. Be sure that the solder is shiny and have flowed to a smooth connection.
It is even possible that you completely missed soldering one of the pins. The first computer I had was built from a kit. The memory boards had 8 kilobytes per board. That was 64 memory IC's with 16 pins per IC. :eek:
When I plugged in one of the boards it did not work. The assembly instructions recommended that the first step was to look for an unsoldered pin on one of the corner pins of the IC's. Lo and behold that is exactly what I found. :)
John O'C
Joined Mar 22, 2017
68
It will be obvious only after 8 pm, and not at all in 12-hour mode.
ak
this might become my fallback position, if I can't resolve it.
Look at the joint on pin 10 of the affected digit.
I am confused as to which pin is which.
I presume there is a standard numbering system for these tubes.
If I look at one of these (from the front), does the numbering go?
1 2 3 4 5
10 9 8 7 6
that is easier said than done, Richard.
A lot of the soldering is obviously hidden behind the number display .
Are there any checks I can do, possibly using a meter, to discover why that middle segment is not lighting?
Thanks for all the help so far folks, it's really appreciated here.
AnalogKid
Joined Aug 1, 2013
12,268
This is a multiplexed display system, so no segment has straight DC on it. Measuring a segment with a DC meter should show some percentage of the system power voltage. Measure a few to get a sense of the range of normal values (probably less than 1.25 V), then measure the bad segment.
ak
dl324
Joined Mar 30, 2015
18,463
There is no single standard pinout for these displays. You can try Googling for "7 segment display pinout". There seem to be a half dozen different pinouts...
Another option is to use the diode check on a DMM. Put the positive lead on one of the common anodes on a display that's working and the other pins one at a time until the g segment lights. Then look at that pin on the display that isn't working.
You could also use your DMM to test the g segment on the display that isn't working. It's possible that it was damaged during soldering.
RichardO
Joined May 4, 2013
2,270
That is easier said than done, Richard.
I was hoping that the displays were in sockets. Since that is not the case things are going to be a bit more difficult.
You can continuity test from the bad segment to the same segment of each of the other displays. If you are not sure the pin for the bad segment you can do a reality check by doing the same continuity test between known good segments.
I see three possibilities at this point.
1. If the bad segment happens to be at the end of the trace it could be a cracked trace.
2. You have a bad solder joint for that bad segment.
3. The display has a bad segment.
It is very likely that you are going to have to remove the display -- either to replace it or to check the traces underneath it. This does not sound like much fun. The biggest damage is that you might damage the traces while removing the display.
John O'C
Joined Mar 22, 2017
68
I sort of understand what you're saying, but at my current level of expertise :confused:, I don't know how to put that into practice, i.e. I just don't know where to put meter leads?
again unfortunately, the above answer probably applies.
if I do it again they will be :rolleyes:
now where have I have that before, the story of my life...
John O'C
Joined Mar 22, 2017
68
I don't unfortunately know which pin those what on my little setup.
Are pins 3 and 8, the common anodes? - Just a wild guess from looking at the schematic.
I think I can work out that pin G equals pin 10 (is that correct?) From the schematic
if only I knew where to put the meter leads
dl324
Joined Mar 30, 2015
18,463
Yes. You can confirm by using the ohm setting on your DMM to check continuity between the pins. If you have 5 pins on each side, 3 and 8 will be the center pins on each side.
It goes without saying that power needs to be off.
Put the positive lead on one of the anode pins and, with the meter on diode check, put the negative lead on the other pins one at a time until you've verified that all of the diodes are good. You should be able to see each segment turn on. As you're doing that, you can draw the pinout for the displays for future reference.
To reiterate, circuit power needs to be off whenever you're measuring resistance or performing a diode check.
John O'C
Joined Mar 22, 2017
68
o_Oo_Oo_O
In an attempt to try and find out the pin numbering, I found a number of the side of the display tube...
10016BTC
I tried googling it but all I got was bitcoin hits
bertus
Joined Apr 5, 2008
23,005
I have taken your fuzzy picture and taken one digit out of it.
I looked at all digits and composed the pin numbers at the display:
Bertus
John O'C
Joined Mar 22, 2017
68
Nothing...
Checked continuity with the power off as per your instructions
nothing...
Checked diodes with the power of as per your instructions
just to confirm it is 5 pins at the top, 5 pins at the bottom
John O'C
Joined Mar 22, 2017
68
KISS and Richard0
Thanks, I can now see the pin order.
10 9 8 7 6
1 2 3 4 5
..if I am correct.
But (see above ), I am not getting any readings even on the good ones, following dl324 instructions
