(I) and DATA used more than once in a program (Oshonsoft)
camerart
Joined Feb 25, 2013
3,853
I'm reading DATA more than once in a program. (Oshonsoft)
e,g, (Not real)
For i = 0 to 5
READ
Next i
Do I need to change i to 'say' have ' ai ' and ' bi ' also ' aDATA ' and ' bDATA ' ? or can the same DIM i as byte work for all ?
Camerart
ericgibbs
Joined Jan 29, 2010
21,567
hi C,
You can, providing when using 'i' in a Loop, you don't come out of the Loop into another 'i' Loop.
The Data would have to be of the same Type, ie; Byte,Word etc..
I would initialise the Data to 0 or "" depending on Type before using.
I would not re-use it in an Interrupt Subr.
E
camerart
Joined Feb 25, 2013
3,853
hi C,
E
Hi E,
Ok, that makes it easier, as long as I remember the rules.
Thanks,
C.
camerart
Joined Feb 25, 2013
3,853
hi C,
E
Hi E,
Here is a program, with char, (I) , b() and data used more than once:
Marked ?????????????????????????
I think I'll get mixed up if I use the same name in different sections, so can I make one of each, 'say' charg, ig, bg() and datag for GPS and 'say' charc for compaas?
C.
