I am solving a question i found in a book on signals and amplifiers.
tTornado
Joined Oct 2, 2020
Exercise says:"An amplifier operating from a single 15 V supply provides a 12 V peak to peak sine wave signal to a 1 kohm load and draws negligible input current from signal source.. The DC current drawn from the 15V supply is 8 mA. What is the power dissipated in the amplifier and what is the ampifier efficiency?
I said:
Pdc= Vdc * Idc = 12 * 0.08 = 120 mW
Pload = (Vo /sqrt(2))^2/Rl = 72 mW
Pdiss + Pl = Pdc + Pi
Since no current is drawn from source, Pi=0 =>
Pdiss = Pdc-Pl = 48 mW
efficiency=Pl/Pdc = 60%.
Answer says: 102mw, 15%.
What am I doing wrong?
MrAl
Joined Jun 17, 2014
13,854
What is confusing here is the 8ma DC current.
An amplifier would not draw a constant DC current like that when supplying an AC sine wave output into a resistive load.
Thus it does not make sense unless we assume maybe one of these two:
1. The 8ma is really the AC current (peak or rms, probably peak if the output is in peak too).
2. The 8ma is a constant DC as stated even though the output load current draw is an AC current.
If #1 then we can figure all AC quantities.
If #2 then we have to assume that the input power to the op amp is 15*0.008 for all time although the output is an AC voltage and AC current. Then the power used by the op amp would simply be the subtraction.
ericgibbs
Joined Jan 29, 2010
21,622
hi Al,
If it is a Class A amplifier, there would a quiescent current flowing in the amplifier, in the absence of any signal input.
The low eff% suggests a Class A amp.?
E
ericgibbs
Joined Jan 29, 2010
21,622
hi Bob
The way I read the TS's question suggests a Class A amplifier with a 8mA quiescent Collector current.
Which gives a quiescent supply Power of 15Vdc * 8mAdc = 120mWatt
A 12Vppk swing across a 1K Collector load gives a Load power of ~18mWatt
Eff%= 18mW/120mW = 15%
These values are the same as the answers as given in the TS's book.
ie: the 8mA is not an RMS value in this case.
E
MrAl
Joined Jun 17, 2014
13,854
hi Bob
E
Hi Eric,
Yes that is a very reasonable interpretation of the initial problem posed in the first post.
In that case, the internal losses due to the output AC would be calculated also and added to the 'quiescent' power loss.
