I am making an amplifier for a piezoelectrical sensor to collect heartbeat data
almaz_so
Joined Jul 3, 2023
10
Hello. I am designing an amplifier which amplifies the signal of a heartbeat( around 1Hz) that is collected from a piezoelectric sensor. I aim to have a ~1V amplitude sine wave output at 1 Hz, and the waveform of other frequency will be filtered out. But right now, I only have an output of 0.16V amplitude sine wave.
Is there any way to increase the gain of the circuit and have a higher voltage output?
Figure 1 Circuit Diagram
Figure 2 Circuit Diagram (with notes)
Figure 3 Output Waveform
almaz_so
Joined Jul 3, 2023
10
almaz_so
Joined Jul 3, 2023
10
ericgibbs
Joined Jan 29, 2010
21,622
hi almaz,
Cleaned up your original asc circuit, it should make it easier to follow any changes you have to make in order to get it working as required.
Correct the excessive gain in the 1st stage.
Don't worry about using boxes for the symbols.
E
Ian0
Joined Aug 7, 2020
13,306
The charge amplifier in the simulation has a DC gain of zillions that amplifies the opamp DC input offset voltage.
Agreed. What’s this obsession with charge amplifiers for piezo transducers. What’s wrong with an ordinary non-inverting op-amp stage, using a FET op-amp to get a high-impedance input?
Do the filters need to be so complicated? Has the TS quantified the interference signals that need to be removed?
almaz_so
Joined Jul 3, 2023
10
hi almaz,
E
But If I use another model (the one with the voltage source) of the sensor, the maximum gain will be around 10dB
