void fnCalc_Disp_pH (int itempe)
{ float fpHread=0;
int k;
// Now Calc ph !
fnADCInit(5,'h');
for(k=0;k<8;k++)
fpHread=fpHread+fnADCConv1024Avg();
// before going any further,check if the mode flag was raised
// if yes,then just return to the calling function
if(cModeFlag==1)
cModeFlag=0; // reset flag for future use
return;
// Average of the 8 averages
fpHread=((int)fpHread>>3);
// Now that we have the average of thousands of readings
// Lets interpret it !
// convert to mV
fpHread =((((fpHread/1023)*(5000)))/5);
// Calc actual mV (since sensor's ground is raised by 0.5V)
fpHread=fpHread-500;
// COMPENSATE FOR 0mV OFFSET
// THE BELOW CODE COMMENTED OUT AS IT COMPENSATES BY AFTER
// CONSIDERING THE OFFSET POLARITY
// IN THE LATEST READINGS,I'VE FOUND OUT THAT THE OFFSET REAMINS MORE OR LESS
// THE SAME FOR -VE OR +VE READINGS. MORE IMPORTANTLY,THE Pt100 INJECTS A STEADY OFSET OF ABOUT 28mV
// AND THAT HAS TO BE COMPENSATED FOR EVERY WHERE
// SO JUST SUBTRACT THE 0mV OFFSET FROM ALL READINGS !!!
/* Generally,the 0mV offset is +ve and is not reflected in basic sol.
But , hypothetically,there could be a scenario where this was -ve
So we check the offset first. If it's positive,then we applyy it
only to +ve mV values (acids)
Else we apply it ONLY to -ve mV (basic sol)
if( gf7pHOffset > 0 )
if(fpHread > 0)
fpHread=fpHread - gf7pHOffset ;
else if( gf7pHOffset < 0 )
if(fpHread < 0)
// COMPENSATE FOR 4 pH OFFSET WHICH IS ACTUALLY THE TEMP OFFSET
// This,again,has to be done for all values !!!
fpHread=fpHread + (fpHread*gfOffsetPermV) ;
// Smoothen out the jitter
// If new reading is less than old one,then display the old one itself
// but also store the new reading
if (fpHread < gfpHOldVal)
float fTempVar=fpHread; // temp. store new reading
fpHread=gfpHOldVal; // New reading is less. So replace it with old reading
gfpHOldVal = fTempVar; // Insert new reading as the next "old reading"
else
{ gfpHOldVal=fpHread ; }
// Temperature compensation
fnSetpHSlope(itempe);
// CODE FOR "BANDING"
// "band" for 7 pH
if((fpHread > (-6))&&(fpHread < (6)))
{ fpHread = 0 ; }
// "band" for 4 pH
float f4Band = (3*pHSlope);
if( (fpHread >(f4Band-6)) && (fpHread<(f4Band+6)) )
{ fpHread = f4Band ; }
// "band" for 9.18 pH
float f9Band = -(2.18*pHSlope);
if( (fpHread >(f9Band-6)) && (fpHread<(f9Band+6)))
{ fpHread = f9Band ; }
// display in .01 * pH
fpHread =((7-(fpHread/pHSlope))*100);
// Display pH
fnDispNum(fpHread);
// Add the decimal point
gcSSEGdispHexCode[2]=(gcSSEGdispHexCode[2])&(0B11111011);
// Disable the highest 7seg if ph<10
if ( fpHread < (1000) )
gcSSEGdispHexCode[3]=0xff;
ERRORS ARE AS:
0 1 mikroCPIC1618.exe -MSF -DBG -pP16F877A -DL -O11111114 -fo20 -N"G:\ph_meter\main.mcppi" -SP"C:\Users\Public\Documents\Mikroelektronika\mikroC PRO for PIC\Defs\" -SP"C:\Users\Public\Documents\Mikroelektronika\mikroC PRO for PIC\Uses\P16\" -SP"G:\ph_meter\" -SP"D:\ph_meter\" "main.c" "__Lib_Math.mcl" "__Lib_MathDouble.mcl" "__Lib_System.mcl" "__Lib_Delays.mcl" "__Lib_CType.mcl" "__Lib_CString.mcl" "__Lib_CStdlib.mcl" "__Lib_CMath.mcl" "__Lib_MemManager.mcl" "__Lib_Conversions.mcl" "__Lib_Sprinti.mcl" "__Lib_Sprintl.mcl" "__Lib_Time.mcl" "__Lib_Trigonometry.mcl" "__Lib_Button.mcl" "__Lib_Keypad4x4.mcl" "__Lib_Manchester.mcl" "__Lib_OneWire.mcl" "__Lib_PS2.mcl" "__Lib_Sound.mcl" "__Lib_SoftI2C.mcl" "__Lib_SoftSPI.mcl" "__Lib_SoftUART.mcl" "__Lib_ADC_A_C.mcl" "__Lib_EEPROM.mcl" "__Lib_FLASH_RW.mcl" "__Lib_I2C_c34.mcl" "__Lib_PWM_c21.mcl" "__Lib_SPI_c345.mcl" "__Lib_UART_c67.mcl" "__Lib_PortExpander.mcl" "__Lib_CANSPI.mcl" "__Lib_CF.mcl" "__Lib_GlcdFonts.mcl" "__Lib_Glcd.mcl" "__Lib_LcdConsts.mcl" "__Lib_Lcd.mcl" "__Lib_RS485.mcl" "__Lib_S1D13700.mcl" "__Lib_T6963C.mcl" "__Lib_SPIGlcd.mcl" "__Lib_SPILcd.mcl" "__Lib_SPILcd8.mcl" "__Lib_SPIT6963C.mcl" "__Lib_EthEnc28j60.mcl" "__Lib_EthEnc24j600.mcl" "__Lib_TouchPanel.mcl"
0 1501 Specified search path does not exist: 'D:\ph_meter'
0 1139 Available RAM: 352 [bytes], Available ROM: 8192 [bytes]
0 122 Compilation Started stdlib.h
256 315 Invalid expression main.c
253 402 ; expected, but 'float' found main.c
256 424 '}' expected ';' found main.c
262 371 Specifier needed main.c
262 396 Invalid declarator expected'(' or identifier main.c
262 300 Syntax Error: ')' expected, but '>' found main.c
262 300 Syntax Error: ')' expected, but '-' found main.c
263 300 Syntax Error: ')' expected, but ';' found main.c
271 393 'fnDispNum ' Identifier redefined main.c
273 402 ; expected, but '=' found main.c
273 393 'gcSSEGdispHexCode' Identifier redefined main.c
273 312 Internal error '' main.c
0 102 Finished (with errors): 15 Nov 2017, 23:00:22 main.mcppi
Kindly help me out as soon as possible.
{ float fpHread=0;
int k;
// Now Calc ph !
fnADCInit(5,'h');
for(k=0;k<8;k++)
if(cModeFlag==1)
return;
// convert to mV
if(fpHread > 0)
if(fpHread < 0)
else
// "band" for 7 pH
{ fpHread = 0 ; }
// "band" for 4 pH
// Display pH
fnDispNum(fpHread);
ERRORS ARE AS:
