HVAC compressor motor potential relay coil ohms read 5.94k, is that ok? # Mars 65
sdowney717
Joined Jul 18, 2012
805
I have not tried it on the machine.
It got wet and I cleaned it off
The relay points are good.
AFAIK, the back EMF on these motors reads around 400 vac.
As motor gets up to speed, back EMF rises until this relay kicks the start capacitor out of the circuit.
Does coil ohms of 5.94k create enough magnetism effect to pull in the relay?
This coil is made of a very fine wire with many turns
The points arm is lightly sprung.
