HV-eman12
loosewire
Joined Apr 25, 2008
1,686
on utube there is video clip that shows a high voltage lift that works very
good .You can see all the parts close up and like you say( Bill) it lift's
30 feet and is very dangerous. check it out you will be impressed.
mrmeval
Joined Jun 30, 2006
833
Without a link it sounds like I'm supposed to boost up someones google/youtube hit count without you being called a spammer.
Dave
Joined Nov 17, 2003
6,969
Please do not name members directly in thread titles - if you want to alert a member to a thread you have started please use the PM system to draw their attention to it. Thank you.
Dave
Wendy
Joined Mar 24, 2008
23,859
Actually I've seen quite a few. What I would like to see is a light weight HV circuit, which is probably an oxymoron, that could be lifted by a bank of lifters. A self contained flying machine in other words.
There is a lot of voodoo associated with these gadgets. There is no doubt they work, but people keep insisting they are a form of anti gravity, which is a load of BS. My believe is they are ionic thrust, which would be easy to test. Put one in a bell jar and pump the air out, it would also probably create some nifty pyrotechnics besides in a low pressure atmosphere.
hgmjr
Joined Jan 28, 2005
9,027
My belief is they are ionic thrust, which would be easy to test. Put one in a bell jar and pump the air out, it would also probably create some nifty pyrotechnics besides in a low pressure atmosphere.
I share your belief in this explanation. As a matter of fact, I saw a recent episode of the TV Show "Mythbusters" where they performed the experiment you describe. There was no movement of the light weight structure.
hgmjr
SgtWookie
Joined Jul 17, 2007
22,230
Bill,
You ain't just a-kiddin' about those pyrotechics. :eek: Airborne radars have to have the entire high voltage and waveguide sections pressurized, or severe arcing will result at altitude.
If you put a HV supply in a bell jar and pumped the air out like you suggest, it would arc itself to death unless everything was insulated.
loosewire
Joined Apr 25, 2008
1,686
Members that would like to veiw the H-V lift can do so by going to
utube. Search(8-CAPACITOR WASHER LAUNCHER) you can select the replay icon as many times as you wish.You will hear the curcuit described
while the procedure is repeated.You can see the parts close up to I.D.
most of the electronic curcuit. You can see a very large metal washer lifted 30 feet.
