Hi Everyone! I hope everyone had great Holidays!
I am currently working on crafting logic to handle a file upload using an ESP8266 as a Webserver (C NON-OS SDK).
So, While wrapping my head around the protocol it seems pretty straight forward. It sends the HTTP header with a Content-length and a binary blob wrapped between something like this.
Now when I get my first POST
First Packet Init
2nd packet
End of packet, Full size of packet is around 226k bytes
Now, My chip cant easily store Binary blobs in memory due to the constraint of local memory. So the steps I am taking right now is
First Packet Arrived
Parse Content-Length using atoi
Extract Form boundary
Set Global Var to note the remote port and mark it as a File Transfer
The second Packet arrives
seek to CRLFCRLF and remove the bytes seeks from the total content length
REPEAT Until Bytes left is less than MTU(1460)
GET PACKET, Write Data to SPI, Subtract Length from Content-Lengths global var
(When packet is less than MTU, Assumed to be last packet chunk)
REPEAT UNTIL NEXT EIGHT BYTES HAVE \r\n\r\n------ for Mime Border
Anyone have any tips on how to properly parse this data. If I had Vb.Net with 8GB of memory no problem but if you analyze the end of the last packet, I'm wondering if there is a better way to logically go upon this. The Content-length Data removed during the first seek only removes about 60% of the header content from the content the other 40ish percent is at the end but it doesn't appear absolutely predictable as the packet comes in because the true filesize is really unknown. Unless someone can chime in to say maybe that Mime Content is ALWAYS A set amount of bytes for a transfer of one file or something else along those lines that will be very helpful. If you think the check for the 8 Bytes ahead is a perforamnce effective soultion then that works for me. I only need to provide for one file in the file upload.
Thank you!!
First Packet Init
Code:
POST /upload HTTP/1.1
Host: 192.168.1.71
Connection: keep-alive
Content-Length: 226033
Cache-Control: max-age=0
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36
Origin: http://192.168.1.51
Content-Type: multipart/form-data; boundary=----WebKitFormBoundary0fb1BQ5qYnyFdhgn
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Referer: http://192.168.1.51/
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
Code:
0000 a0 20 a6 04 0b be 24 05 0f e3 a5 14 08 00 45 00 ¦..¾$..ã¥...E.
0010 05 dc 10 8b 40 00 80 06 60 fd c0 a8 01 10 c0 a8 .Ü..@...`ýÀ¨..À¨
0020 01 33 c2 b9 00 50 28 bd a1 aa 00 00 19 72 50 10 .3¹.P(½¡ª...rP.
0030 fa f0 e1 f5 00 00 2d 2d 2d 2d 2d 2d 57 65 62 4b úðáõ..------WebK
0040 69 74 46 6f 72 6d 42 6f 75 6e 64 61 72 79 30 66 itFormBoundary0f
0050 62 31 42 51 35 71 59 6e 79 46 64 68 67 6e 0d 0a b1BQ5qYnyFdhgn..
0060 43 6f 6e 74 65 6e 74 2d 44 69 73 70 6f 73 69 74 Content-Disposit
0070 69 6f 6e 3a 20 66 6f 72 6d 2d 64 61 74 61 3b 20 ion: form-data;
0080 6e 61 6d 65 3d 22 66 69 6c 65 54 6f 55 70 6c 6f name="fileToUplo
0090 61 64 22 3b 20 66 69 6c 65 6e 61 6d 65 3d 22 74 ad"; filename="t
00a0 65 73 74 66 6f 74 61 2d 30 78 30 31 30 30 30 2e estfota-0x01000.
00b0 62 69 6e 22 0d 0a 43 6f 6e 74 65 6e 74 2d 54 79 bin"..Content-Ty
00c0 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f pe: application/
00d0 6f 63 74 65 74 2d 73 74 72 65 61 6d 0d 0a 0d 0a octet-stream....
00e0 ea 04 00 00 04 00 10 40 00 00 00 00 80 05 03 00 ê......@........
00f0 90 83 fe 3f 60 84 fe 3f 08 0e 10 40 6b c0 3f 00 ..þ?`.þ?...@kÀ?.
0100 b8 83 fe 3f 08 84 fe 3f 38 08 00 60 40 10 20 40 ¸.þ?..þ?8..`@. @
0110 98 0f 00 40 50 4c 00 40 94 19 10 40 d0 4c 00 40 ...@PL.@...@ÐL.@
0120 12 c1 f0 09 31 f9 21 fd 01 21 f1 ff 31 f2 ff 01 .Áð.1ù!ý.!ñÿ1òÿ.
03b0 70 79 5f 66 72 6f 6d 00 04 08 10 0c 04 08 10 0c py_from.........
03c0 00 00 20 42 00 00 80 43 00 00 00 00 00 00 20 41 .. B...C...... A
03d0 25 73 20 25 75 0a 00 00 6d 61 69 00 74 69 6d 00 %s %u...mai.tim.
03e0 45 3a 4d 20 25 64 0a 00 25 78 20 61 6c 72 65 61 E:M %d..%x alrea
03f0 64 79 20 66 72 65 65 64 0a 00 00 00 2c 01 00 00 dy freed....,...
0400 18 fe 34 00 ff ff ff ff ff ff 00 00 25 30 32 58 .þ4.ÿÿÿÿÿÿ..%02X
0410 00 00 00 00 25 30 32 78 00 00 00 00 6d 61 63 00 ....%02x....mac.
0420 70 6d 00 00 66 70 6d 00 70 70 00 00 64 65 76 00 pm..fpm.pp..dev.
0430 88 85 fe 3f 50 e8 fe 3f 00 00 00 00 00 00 00 00 ..þ?Pèþ?........
0440 00 00 00 00 00 00 00 a5 0d 0a 2d 2d 2d 2d 2d 2d .......¥..------
0450 57 65 62 4b 69 74 46 6f 72 6d 42 6f 75 6e 64 61 WebKitFormBounda
0460 72 79 30 66 62 31 42 51 35 71 59 6e 79 46 64 68 ry0fb1BQ5qYnyFdh
0470 67 6e 0d 0a 43 6f 6e 74 65 6e 74 2d 44 69 73 70 gn..Content-Disp
0480 6f 73 69 74 69 6f 6e 3a 20 66 6f 72 6d 2d 64 61 osition: form-da
0490 74 61 3b 20 6e 61 6d 65 3d 22 73 75 62 6d 69 74 ta; name="submit
04a0 22 0d 0a 0d 0a 55 70 6c 6f 61 64 20 49 6d 61 67 "....Upload Imag
04b0 65 0d 0a 2d 2d 2d 2d 2d 2d 57 65 62 4b 69 74 46 e..------WebKitF
04c0 6f 72 6d 42 6f 75 6e 64 61 72 79 30 66 62 31 42 ormBoundary0fb1B
04d0 51 35 71 59 6e 79 46 64 68 67 6e 2d 2d 0d 0a Q5qYnyFdhgn--..
Thank you!!
