HT66F0021 with ADC -- Holtek contoller
Jeevi@1209
Joined Nov 22, 2024
I am using HT66F0021 controller interfacing with adc. I am new to this controller.I am not able to read the ADC value, my condition is not becoming true and I am not having uart to print the data. I have attached my code for reference. I am using AN2 channel.
Mod: please use Code display option, top on this post menu bar ....
C-like:
#include "HT66F0021.h"
void Delay_ms(unsigned int count);
void McuConfig(void);
void GpioConfig(void);
void AdcConfig(void);
void AdcMeasure(void);
unsigned int AdcResult = 0;
void main()
    McuConfig();
    while (1)
        AdcMeasure(); // Update AdcResult with the current ADC value
        if (AdcResult > 512) // Compare ADC result
            _pa5 = 1; // Set PA5 high
        else
            _pa5 = 0; // Set PA5 low
        Delay_ms(100); // Delay for stability
    char i, j;
    for (j = 0; j < count; j++)
        i = 100;
        while (i)
            _clrwdt(); // Clear watchdog timer
            _nop(); // No operation (multiple for timing adjustment)
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            i--;
    GpioConfig();
    AdcConfig();
    _pac = 0b10011011; // Configure port A as needed
    _pa5 = 0; // Set PA5 to low initially
    _pac5 = 0; // Configure PA5 as output
    _sadol = 0; // Clear ADC data low byte
    _sadoh = 0; // Clear ADC data high byte
    _sadc0 = 0b00010000; // Configure ADC settings (e.g., clock, mode)
    _sadc1 = 0b00000100; // Enable ADC and set input channel
    _pasr = 0b01100000;  // Select ADC channel (e.g., PA5 as input)
    _start = 1; // Start ADC conversion
    while (_adbz); // Wait for ADC conversion to complete
    _start = 0; // Reset the start bit
    // Read ADC result
    AdcResult = (_sadoh << 8) | _sadol; // Combine high and low bytes
    //AdcResult = (_sadoh << 2) | (_sadol >> 6); // Combine high and low bytes
