HP DL380 Linux Desktop
joeyd999
Joined Jun 6, 2011
6,413
The size and possible fan noise is the major things needed to plan for.
I would get the DL380 2U version as they tend to be less noisy and easier to work on with more space inside.
It's going into my server room...size, noise, power not a big deal to me.
A cheap GT 1030 will all you to run most desktop graphic systems like KDE/Plasma.
For the most part, it'll run headless.
Linux should install quickly out of the box but there are quirks with the needed non-free firmware for the network cards...
Elaborate, please: is the firmware available via distro? Or I have to download from HP?
What's the network speed with and without the firmware?
I'll be running multiple VMs on this, each providing various services that separate boxes currently host. I've gotten tired of maintaining each box, so I figured something like this will help clean things up.
The old DL140 finally is giving up the ghost. Random lockups likely related to old filter caps. Some are tenting.
Those old drives were troopers.
POWER ON HOURS!
Lots of errors but it was still running after 141,247 hours.
Replacement server going in the slot.
joeyd999
Joined Jun 6, 2011
6,413
View attachment 329684View attachment 329685
POWER ON HOURS!
Can you pop the drives into the new box carry on?
My oldest Linux DL production system is finally decommissioned.
Sanitize the drives and boom, into the recycle bin. Looks pretty clean for running 18 years 24/7.
The next new old champ is an old DL380 GEN3.
Hiding behind lead doors and ceilings to protect it for X-rays.
Old school motor generator for AC power isolation with insulated power shaft.
Provides secure remote access and backups for processing tools.
Hi, if I can know what Debian do you use ?, I usually use ubuntu but its not windows friendly and make problems for my employee, your Debian looks very windows friendly
I don't use Debian today because I hate Systemd. My production and home machines all use Devuan except those that run the Home Assistant software suite. That requires Systemd, so it runs on an isolated server just for that only.
https://www.devuan.org/
Devuan GNU+Linux is a fork of Debian without systemd that allows users to reclaim control over their system by avoiding unnecessary entanglements and ensuring Init Freedom.
I don't know what you mean by windows friendly as there is no Microsoft Windows OS software on these machines, only Linux native applications and OS.
meowsoft
Joined Feb 27, 2021
666
Looks at that video, its GUI appear more like windows, that I mean "Windows Friendly", more clearly "Windows Like GUI"
Looks at those start menu and windowing system, looks more Window-ish GUI
I'm using the ICEWM GUI window manager in W95 mode. It's very simple and direct. Easy to set up for none of that cpu/gpu wasting cycles bling BS you see in most managers. You can install it from the distro package archive.
I normally use that interface when the normal users likely use Windows.
This is a remote access application that uses a secure Linux server for remote operation of processing tools. Icewm with the Windows 95 interface is easy for them to use without training.
