How would you interface a relay to control an AC device
MaxHeadRoom
Joined Jul 18, 2013
30,808
Common in this context is not the power supply common, it means it is the 'Common' terminal WRT the other two (N.C. & N.0.).
Even when using one pair of contacts, it is customary to show power into the COM terminal of the relay, although electrically it will result in the same effect.
Albeit in this case it would not matter, just custom.
28,242
With noormal AC mains wiring it is better to refer to that side of the circuit as "neutral," not "common", which is a better term than "ground." Certainly the jargon of the realm in electrical discussions can be confusing for those uninformed.
MaxHeadRoom
Joined Jul 18, 2013
30,808
But the Common in this context is in reference to a relay terminal, NOT the supply.
In any case, ground as used in N.A. is confusing as it is also a term for Earth connection.
35,170
Should the LINE input be connected to NO terminal or COM terminal?
My vote would be that LINE is connected to NO terminal. Load is connected to COM terminal.
The reason for this you don't want LINE to appear on NC terminal when the relay is not activated.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Why not?
If it is not being used it is moot.
28,242
LINE voltage stays put and doesn't move. One less thing to go wrong from an accidental short to NC.
The concern that I have is that on some small relays the moving contact is solidly connected to the relay frame. So the entire relay frame, and any conducting material it is mounted on, is connected to the switched circuit. THAT is a real potential problem.
GetDeviceInfo
Joined Jun 7, 2009
2,284
Personally, I'd place it on com, which would maintain the logic of NC/NO, as well as making them available without rewiring, should a need for the other logic arise.
