How to wire TWO switches to control polarity
RIKRIK
Joined Oct 11, 2019
146
What are you using the motor for? is it something you could just switch off and let slow down for a direction change?. if so a third on off switch before the two relays may help. or a on,off,on switch to give the motor time to fully stop. if not then you can get a 10a hbridge from aliexpress for about a tenner.
sghioto
Joined Dec 31, 2017
8,758
The resistor may be all you need. I'm not and expert on this but I would start at say a 20 ohm 20 watt resistor.
The diodes are there for inductive transient suppression, but if all you have is a switch, battery and a motor they may not be needed unless other sensitive electronics are connected.
Recommended is a fast recovery diode. The only part that comes to mind is a 1N5819. Maybe someone else can suggest a more suitable component.
