Hi there,
I am looking to build Bluetooth speakers with tweeters and woofers in parallel for each side, through a crossover.
I was wondering if there is a possibility of wiring a potentiometer to control the volume of all four speakers - if so where would they be wired?
I have attached a really rough outline of the the circuit beginning to take shape, as it is only beginning any extra advice about where things are not wired properly would be a great help. Is it possible to connect more than 1 wire to a single spot on the amp board?
The amp board is TDA7492 - it has the control buttons, but if it is possible I would prefer the volume knob.
I would also like to place a red LED indicator for power and on/off toggle switch.
Any feedback and advice would be appreciated.
Thank you!!
Thank you!!
