Your switch is a momentary two pole switch. Each pole has two contacts. One set of those contacts is normally open. And the other pole set of contacts are normally closed.
When you push the switch..............the pole that was open will close..........and the pole that was closed will open.
So with a push or the release of a push......you get two functions or two actions.
