how to use transistors circuit as DPDT relay
Adam King
Joined Nov 19, 2009
5
Hi guys, i've been trying to build a circuit that would substitute a DPDT relay using transistors with full isolation, yet i am still no where.....any idea ???
thanks
Adam
22,096
What do you mean by "full isolation"? Normally you isolate either the inputs or the outputs, but not both.
I don't think you can get behavior equivalent to a relay with a BJT. You might have better luck with a FET, or a BJT controlling the gate of a FET.
Would some kind of opto-isolator possibly fulfil your requirements?
Adam King
Joined Nov 19, 2009
5
Well, I have a DPDT relay; one of the poles is connected to the positive lead of a capacitor “47MF- 16V” and one of the throws is connected to the positive of 12 V DC power supply, the third throw is connected to a transistor, the capacitor charges itself when the relay is OFF then when the relay turns ON the capacitor discharges itself into the transistor, so what I really want is to replace this mechanical relay with transistors circuit.
Thanks
22,096
Thanks
What about the other pole, and why the need for isolation?
hobbyist
Joined Aug 10, 2008
892
Thanks
Is this any where close to what you have right now?
