How to use MINMAX
mothermohammad
Joined May 17, 2014
69
I designed a DC-DC converter and for the MOSFET driver (TLP250) I need 2 MINMAX for isolated power source (12volt). However, I don't know which MINMAX is suitable for my circuit. There are many MINMAX with a wide range of power. why the power of a MINMAX is important? How its output current should be considered?
I am thankful if someone gives me instructions for using MINMAX in a DC-DC converter.
Thank you so much
schmitt trigger
Joined Jul 12, 2010
2,290
As atferrari mentions, probably the product line name for a family of switching regulators.
But without a schematic datasheet or at least a web page link, all we can do here is twiddle our thumbs.
mothermohammad
Joined May 17, 2014
69
My meaning as MINMAX is a DC-DC regulator for providing an isolated DC voltage for a MOSFET driver to switch a MOSFET. I put the link of a MINMAX which converter a 12 volt to isolated 12 volt.
https://www.cdiweb.com/products/detail/mau218-minmax-technology/218387/
Please note that I need two MINMAX IC to have two isolated power supply for TLP250 (MOSFET Driver).
This is the picture of my circuit
As it is clear there are 3 distinctive ground (N, M, and P). The N is the main ground of the system. The M and P are the groud of the two isolated power supply which will be provided by MINMAX IC.
mothermohammad
Joined May 17, 2014
69
I am so thankful if you let me know which ampere is needed for the gate of an IRFP250M MOSFET.
In this regard, I can select the needed MINMAX.
