Here's a newbie question for you folks! I've got a stereo amplifier, the type that is used for communications at a bank counter. It has one button type microphone and one 8 ohm speaker on each side of the seperating glass.
The amp has volume controls on the front for the staff to use. It also has pots at the rear that are used to set the sensitivity of each channel/customer and staff side respectively. If the rear pots are turned up too far then there is feedback. The trick is to set each channel at 50% to get maximum effectiveness. If one channel is turned higher than the other then it will be louder than the other one.
Is there a way of injecting a signal into each microphone input at the same time and then measuring the output as one adjusts the rear pots? To complicate things, I do not have an oscilloscope but would be willing to tackle a small measuring circuit of some description. Any help out there??
